It is currently Sat Feb 28, 2015 5:03 pm
 Post subject: can anyone tell me?
PostPosted: Sun Jan 09, 2005 8:43 pm
can anyone tell me what hardware do i need for my 2 computers to share a network
PostPosted: Sun Jan 09, 2005 10:51 pm
router. linksys makes very good routers.
PostPosted: Sun Jan 09, 2005 10:58 pm
Wired
Setup one (typical)
Two LAN cards (I recommend Netgear)
A hub or a router - the router is useful if you want to share a high-speed connection in the future
2 cables
Setup 2 (oddball)
You still need the LAN cards, but you could get a cross-over cable (instead of a patch cable). I really don't recommend this, as it limits you - both the distance of the cable, but more importantly the fact that you can only have two computers on such a network. With a hub/router you can have several computers. You may want this if you have friends come over for a LAN party.
Wireless
Wireless cards (Again, I recommend Netgear)
A wireless hub/router/access point
How old is your computer? If it was made in the last three years (the motherboard, at least), I can't imagine it not having a network card, possibly even integrated into the board.
I don't know if this is typical, but I've had many troubles configuring networks where wireless and wired computers are involved. Unless you must, I recommend sticking with either wireless or wired, but not a combination.
Peace,
Jacob
 Post subject: Re: can anyone tell me?
PostPosted: Mon Jan 10, 2005 6:01 am
simple answer: a SWITCH
PostPosted: Mon Jan 10, 2005 8:19 pm
a switch/hub and 2 cat5 cables OR a cat5 crossover cable
PostPosted: Mon Jan 10, 2005 8:35 pm
I'm going to throw out the obligatory Null modem cable :)
PostPosted: Wed Jan 12, 2005 5:48 am
:lol:
