It is currently Mon Apr 20, 2015 10:11 pm
 Post subject: noob question
PostPosted: Sun Jan 09, 2005 3:50 pm
i have netzero dial up internet and 2 computers i want to connect to the internet with the 2 computers at the same time how do i do that?
PostPosted: Sun Jan 09, 2005 3:57 pm
with dial-up? you may be able to do it if you hook your 2nd computer to your 1st comp (with the modem) through a second nic and share the connection. i'm not sure how it would work out though as i've never tried that method with dial-up. the connection may be so slow that it may not even b worth the trouble. i've never heard of anyone using hubs with dial-up. hopefully someone will have some first hand experience with doing that.
 Post subject: anywho
PostPosted: Sun Jan 09, 2005 4:19 pm
i'll try that some other time another qustion what kind of hardware do i need so i can play a 1 vs 1 game on my 2 computers
PostPosted: Sun Jan 09, 2005 4:37 pm
Celeron
Celeron
I'm a noob at networking, but I think you need a switch, 1 nic for each PC, and cables if you want to play a LAN game.
PostPosted: Sun Jan 09, 2005 4:54 pm
what is a nic?
PostPosted: Sun Jan 09, 2005 4:57 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
A nic card is a standard network card. You can get one really cheap off newegg.......
http://www.newegg.com/app/ViewProductDe ... 101&depa=5
PostPosted: Sun Jan 09, 2005 4:58 pm
Celeron
Celeron
NIC = Network Interface Card. A networking port.
PostPosted: Sun Jan 09, 2005 6:35 pm
Normally I'd say you'd want to use ICS or some sort of sharing software like winproxy or sygate..but I seem to recall you couldn't use that with NetZero as they had some propiatory dial up manager that didn't work with it.
