It is currently Fri Apr 17, 2015 8:17 pm
 Post subject: 2 Nics + wireless question
PostPosted: Wed Jan 05, 2005 4:27 pm
okay my comp has two on Board nics(asus A7n8x-e Deluxe) i was wondering if i plug in two ethernet cables from my switch, can i bridge one of them to my onboard Asus Wifi card so i can connect wirelessly to a comp that i want to put in my closet and just let it run. well i know that can be done, but heres my question can i do that and still use my other NIC as the main one in my comp for everything else, basically i want my 2nd nic to go straight to the wireless and not affect my primary nic, which is gigabit, compared to 100mbit
edit
o yeah i will put a drawing of what i want to do in a few minutes
*runs off to paint*
edit for pic
PostPosted: Thu Jan 06, 2005 7:34 am
I guess you could...Your PC would need to act as a router...
You would need some static routes that would point traffic destined for the wireless through the Ethernet interface..I have never done that but I'm sure its 'google-able'.
Question...Why not jsut connect a WAP to the switch?
PostPosted: Thu Jan 06, 2005 9:03 am
If I'm not mistaken, you should just be able to put the wireless adapters in Ad-hoc mode to talk directly to eachother (since there's not wireless AP). Then, you would just enable ICS*, so that your main PC becomes a sort of gateway between that PC and the internet.
*=assuming you have an OS that supports ICS, like XP.
PostPosted: Thu Jan 06, 2005 12:42 pm
... in the absence of ICS IP Masquerading/NAT can be used.
