It is currently Mon Mar 30, 2015 3:15 am
 Post subject: internet connection problem..can't browse.. HELP PLS
PostPosted: Sun Jan 02, 2005 4:58 pm
xp home
i've reset the tcp/ip protocol, removed every app i can think of and all the spyware bot crap, on linksys router dhcp
i can't browse any sites..
times out when i ping www.yahoo.com
but perfect when i ping their ip
any hints??
thanks
PostPosted: Sun Jan 02, 2005 8:41 pm
ummm.......provide a bit more info if you can. are you using DSL or cable as your isp?
PostPosted: Sun Jan 02, 2005 10:18 pm
i'm on cox cable, but am using a router..
the system's ip is correct, the dns is correct... everything i have checked is right.. i've checked everything i can think of.. reset the tcp/ip protocol, cleared the cache.. removed anything that remotely could be screwing it up, safe mode, all startup items disabled.. i can ping the hell out of any site as long as i use the ip address... cant use the name address though... this problem really has me stumped.... i don't know.. i think i'm going to reinstall windows in the morning..
i'll try any tips
thanks
PostPosted: Wed Jan 05, 2005 8:06 pm
First plug your modem directly into your NIC. Also make sure your cable modem lights are correct. If it's a motorola modem, all four lights should be solid, then the fifth green or orange activity light should be blinking.
If you can connect with just the modem hooked stright to the nic on the back of your PC, then it's obvious your router isn't getting an IP from your modem. So just hook everything backup, and this time unplug your modem for 30 seconds. Hook it back up, then unplug the power to your router for 30 seconds. Plug it back up.
Next go to the routers internal setup page and reset everything up, this time checking the status page and make sure your router is pulling an IP from your cable modem and that it's assigning an ip to your PC(s) (i.e-a 192-172 addy)
