It is currently Mon Apr 20, 2015 10:18 pm
 Post subject: D-LINK DI-624 WON'T PLAY WITH MY DSL!
PostPosted: Sun Dec 26, 2004 1:59 pm
Followed the instructions to the letter. Went to connect, I'm online but I can't do anything. If the thing won't go on line how can I do a firmware update? The installtion disk is garbage.
HELP!
RAINMAN
PostPosted: Sun Dec 26, 2004 2:36 pm
don't use the installation CD. Perform a hard reset on the router (usually put a pin in the reset hole while plugging the power into it), and waiting a few seconds).
Afterwards, manually log into the router's IP address. The IP address should be in the installation manual, but for D-Link's, I think it's this:
http://192.168.0.1
Under account, enter your DSL username and password, and click UPDATE, or SAVE.
You should now be set up. Other that that, there are security precautions you might want to take, like restrict access so that other people can't use your connection, or set up a firewall, that that's a whole other topic...
If resetting the router still doesn't work, call up a tech representative, your router may have a problem..
PostPosted: Sun Dec 26, 2004 4:24 pm
Is your Internet connection cable or DSL? If it is DSL, is the connection PPPOE or not?
