It is currently Sun May 03, 2015 4:19 pm
 Post subject: Strange setup problems with DSL and Linksys Router
PostPosted: Thu Dec 23, 2004 9:14 am
Hey everyone.
Just setup a Linksys Wireless router at my girlfriend's parents place, who just got DSL. However, in order to get it to work, we had to plug the DSL into a regular port in the Linksys router (not the uplink port). I figured that we may need to do something like this because the DSL modem may actually be a router as well, and for whatever reason won't plug into the uplink port.
In any case, this seemed to work brilliantly until we tried to get two wireless cards to connect at the same time. Once I started up my computer, my girlfriend received an "IP Conflict" message, and I was unable to login at all.
Is there any way that we can fix this so that both of us can use wireless at the same time?
Thanks!
PostPosted: Thu Dec 23, 2004 10:10 am
King of All Voodoo2 Cards
Are you with a company called Bridgecom or Broadcom?
PostPosted: Thu Dec 23, 2004 10:14 am
No. The modem is "Speedstream" if that's what you're asking.
I don't work with either of those companies if that's what you were asking.
-Jeff
PostPosted: Sun Dec 26, 2004 2:46 am
I think you're confusing something because "UPLINK" basically means it's crossing over the cables -- it has nothing to do with where the high-speed connection plugs into. Are you maybe using a switch instead of a router ?????
UPLINK is used when you're plugging one router into another.
PostPosted: Sun Dec 26, 2004 2:49 am
ohhh my mistake.
Try this one as well:
Log into the router, (usually 192.168.0.1, check your router's documentation) and try changing it's IP address. It could be that both the modem and the router are trying to take control. If all else fails, go onto the computer and set up a static IP address. With that arrangement, you get to specify which is the "default gateway"
manual IP settings:
Default Gateway = IP address of internet connection share
Preferred DNS: 207.69.188.187
Alternate DNS: 207.69.188.186
PostPosted: Sun Dec 26, 2004 10:54 am
I actually played around with it for a bit and figured out the problem. Turns out that with that modem I can pick where PPPoE is done. It was originally set to the modem, I set it to "downstream on Computer or Router" and put the login information into my router. It worked brilliantly. Now the router is appropriately assigning IP addresses to everything connected to it (after pluggint the DSL into the Uplink slot).
Thanks!
-Jeff
