It is currently Wed Jan 28, 2015 11:08 am
 Post subject: How would I set up server through Router
PostPosted: Fri Dec 17, 2004 8:05 pm
Well not just a router but a Router /firewall but before that a switch which goes to a switch then to my server. Plus ts a dynamic ip address. so i am using filezilla server and have ports set to 25-80 and my external port to what it is, and i give people the internal ip but i cannot get people to connect to it... Is there somthing on the Router i must change ro something?....
The Specs are:
Netopia Router
Dlink 16port 10/100 switch
Linksys 5port workgroup switch
Year 2000 Dell Dimension 4300
If you need screenshots or something i will give em to ya if it helps me set this server up, thanks!
PostPosted: Fri Dec 17, 2004 9:26 pm
V||V
V||V
It may not be your network topology as your client configurations. Is the server attached to a domain? if not, is everyone on the same workgroup? are you able to ping the server? are you able to ping any of the workstations from the server itself? why 2 switches? is port fowarding enabled on both of them? is your router configured as a pure packet router or as a gateway?
the more info the better!
-R
PostPosted: Fri Dec 17, 2004 9:38 pm
well irght now i can go to the server insdie my network and see it just find and i have 2 switches because we have computers downstairs and upstaiirs and who really want to run 3 100ft cat5e cables when u cna run just one and make 2 shoter ones?... ill get more info tomaro to tired to think right now
PostPosted: Mon Dec 20, 2004 8:44 am
V||V
V||V
Cool, i was just curious, trying to get an idea of your layout.
-R
