It is currently Wed May 06, 2015 10:41 pm
 Post subject: Network Attached Storage Device
PostPosted: Tue Dec 14, 2004 5:19 pm
King of All Voodoo2 Cards
Is there an external hard drive that plugs into a LAN that's Mac and PC compatible?
PostPosted: Tue Dec 14, 2004 5:28 pm
Maxtor/Linksys no mention of apple :(
Asus again no mention of Apple support
Hmmm. I wasn't much help... sorry...good luck.
PostPosted: Tue Dec 14, 2004 5:44 pm
Smithfield*
Smithfield*
you realize they use two different file systems right?
PostPosted: Tue Dec 14, 2004 6:10 pm
iron colbinator
iron colbinator
I found some stuff on D-Link's Site that looked promising. Check that one out along with their other products, they say they support Apple.
PostPosted: Tue Dec 14, 2004 6:13 pm
iron colbinator
iron colbinator
That's part of the point of network attached storage.
Also, file sharing over the network doesn't necessarily have to do anything with the underlying filesystem, it's all about the file sharing protocols. For example, I can access windows fileshares on my PC from my Mac even though they are NTFS because the file sharing protocols (in this case, SMB) take care of the translations for me.
PostPosted: Tue Dec 14, 2004 6:30 pm
Smithfield*
Smithfield*
o now that i see the link you showed i got it....i thought he wanted something like a maxtor onetouch that he could go between mac and pc on....i got it now....sorry about the confusion.
PostPosted: Tue Dec 14, 2004 6:57 pm
If the drive is formatted to FAT32, both systems will be able to see it.
Here's what I'm looking for, we've got about 6 or 7 machines that need a place on the network they can all access.
Dell Dimension w/ WinXP Home
eMac G4 700 w/ 10.2.8
iMac G4 800 w/ 10.3.x
Powermac Dual G4 w/ 9.2.2
Powermac Dual G4 w/ 10.3.6
Flytrap's 13lb. Laptop w/ WinXP Pro
I need to find some kind of network storage that's crack happy with XP, OS 9, and OS X. The only file system I know they can all read/write is FAT32.
We had a Firewire Drive attached to the eMac, however only the Macs could see it. I was thinking of attaching it to one of the PCs because the PCs can see each other and the Macs can also see the PCs, but the guy I work for is a Mac guy and probably wouldn't spring for that.
I figured there might be some kind of Network Storage Device that brought them all together.
PostPosted: Tue Dec 14, 2004 7:15 pm
iron colbinator
iron colbinator
You can use windows filesharing on all of those platforms (windows would basically be your "host"). Of course there are varying degrees of entertainment for OS 9 vs. OS X which is relatively simple :)
I'm not sure you're going to find a lot of devices like the D-Link (and others) that provide OS 9 access. Some people are pretty good about it, but it seems most everything has moved on to only support OS X.
You could also share your windows fileshare over both AppleTalk and standard Windows file sharing, which would make it easier for your OS 9 box. You could probably use that to "cheat" even with a network shared drive, mount the drive on one of your PCs (or apple machines) then share it out again over AppleTalk or another protocol.
Overall, OS 9 is definitely the deciding factor for you.
PostPosted: Wed Dec 15, 2004 5:59 am
you cuold also take an old machine and jam it full of drives and put Linux on it and run it as a dedicated fileserver.
PostPosted: Wed Dec 15, 2004 1:54 pm
Smithfield*
Smithfield*
i agree with hoody. i do the same thing. i was looking around at NAS and they're expensive. get an old computer off of ebay if you dont already have one and then pack it full of hard drives with good cost/price ratio. and when you want to run games just switch it to boot to XP and run it as a game server.
PostPosted: Mon Dec 20, 2004 4:21 pm
Okay, so we have everything pretty much working, except one thing I'd like to change.
Does anyone know of any PC Software that will allow me to see the Mac OS9 and OS X network shares. I've got a username and password for them but WinXP Pro doesn't want to talk to them.
 Post subject: Re: Network Attached Storage Device
PostPosted: Tue Dec 21, 2004 3:20 am
Team Member Top 100
Team Member Top 100
Here is the review of the ASUS: http://www.tomsnetworking.com/Reviews-1 ... LHDD25.php
PostPosted: Tue Dec 21, 2004 11:47 am
Did you miss my last post by any chance?
