It is currently Sun Feb 01, 2015 4:53 am
 Post subject: low signal strength and speed in wireless network
PostPosted: Fri Dec 03, 2004 3:39 pm
Hi, I just set up a wireless network wtih a Linksys WRT54GS router and WMP54GS card and am having probs in getting good signal. The distance is not that far and wanted to know if anyone has any tricks before I go out and get a high DB antenna...
thanks
 Post subject: Re: low signal strength and speed in wireless network
PostPosted: Fri Dec 03, 2004 3:43 pm
There is no cause for alarm... yet
oceancon wrote:
...wanted to know if anyone has any tricks before I go out and get a high DB antenna...
http://KILLMEPLEASE.com/prod01.htm
http://www.oreillynet.com/cs/weblog/view/wlg/448
http://www.usbwifi.orcon.net.nz/
PostPosted: Sun Dec 05, 2004 5:43 pm
besides the antenna, try moving the wireless router around your place and see if that helps at all.
PostPosted: Sun Dec 05, 2004 8:15 pm
Celeron
Celeron
Canucklehead wrote:
Hot links man! Thanks.
PostPosted: Mon Dec 06, 2004 6:03 am
thanks, I have been doing that but the router is in my home office and the layout doesn't allow for much changing. I'm going to get longer CAT 5 cable to see if I can get the router near the door, away from the plaster wall which I read may impact signal.
I dont have a 2.4 ghz phone but the room where the other desktop is near the side of my house close to my neighbor, who may have such a phone. Could this affect it?
thanks
PostPosted: Mon Dec 06, 2004 12:14 pm
King of All Voodoo2 Cards
Possibly I can go down my street with my cordless phone before losing the signal. Also newer garage door openers can screw with a connection too if your neighbors have one of them.
Just for reference, I got two 6dBi Antennas off eBay for $14 a piece which gave my laptop a huge signal boost.
PostPosted: Sat Dec 18, 2004 8:25 pm
Celeron
Celeron
Dont mean to revive an old topic, but damn... look at the connection speed!
This is up from the normal 11Mbps/Low I was getting before! :)
PostPosted: Sun Dec 19, 2004 11:46 am
Did you invest in some antennas?
PostPosted: Sun Dec 19, 2004 11:56 am
WE used to get the same problem on my fathers laptop. Sometimes It would kick onto some1 elses network on our neighborhood instead of our own, oit was strange, and that caused really low speeds
