It is currently Thu Jan 29, 2015 1:16 pm
 Post subject: Best wireless router?
PostPosted: Thu Dec 02, 2004 6:31 am
What is currently the best wireless router? I need a good router that supports both wired and wireless connections for Internet sharing.
I have three computers. I have two downstairs that can be wired together. Then I have one upstairs that needs to be wireless to access the Internet. I also share files a lot between systems.
PostPosted: Thu Dec 02, 2004 10:14 pm
check this one out: http://www.newegg.com/app/ViewProductDe ... 010&depa=1
i dont have this router but ive heard that this router is pretty good. it comes with both wired and wireless connections.
PostPosted: Thu Dec 23, 2004 7:38 pm
many linksys (maybe all?) are firmware hackable, making for a router that can have twice the features you are buying. I'd suggest reading up on that.
PostPosted: Fri Dec 24, 2004 2:29 pm
i have a linksys WRT54G. it is a wirless g router with a 4 port switch. i never had any problems with it. the set up is quck and easy. it also has a very well designed firmware! I TOTALLY RECCOMMEND IT!
PostPosted: Fri Dec 24, 2004 11:28 pm
M-Powered
M-Powered
No, not all.
PostPosted: Sat Jan 01, 2005 2:40 am
I like that Linksys as well. I went one up on that model with the WRT54G, but may have been a waste of the additional $20.
It works great with the PC with the WMP54GS W/NIC...but that's the only PC with that card and thusly the only one that has the "boost". I've recently added a P5AD2-E Premium wireless to the network, and it can't take advantage of the GS's boost, so I would have been fine with the normal WRT54G.
$50 isn't too bad at all either. Just about every local store around here is asking at least $75 that I've ran across.
PostPosted: Sat Jan 01, 2005 4:27 am
Team Member Top 100
Team Member Top 100
D-link DGL-4300
http://hardware.gamespot.com/Story-ST-15140-1368-x-x-x
Its all a gamer ever needs!
PostPosted: Sat Jan 01, 2005 8:37 am
RickRock wrote:
D-link DGL-4300
Does that router allow simultaneous wireless and wired networking? I only have 1 PC that needs to have a wireless connection to the router. My other 2 PC's will be wired to the router.
PostPosted: Sat Jan 01, 2005 8:44 am
TsunamiZ wrote:
RickRock wrote:
D-link DGL-4300
Just curious, did you actually read the article Rick posted? Your answer is in there. :wink:
PostPosted: Sat Jan 01, 2005 9:22 am
HoOdY wrote:
TsunamiZ wrote:
RickRock wrote:
D-link DGL-4300
The article doesn't mention wired.
PostPosted: Sat Jan 01, 2005 9:26 am
RickRock wrote:
D-link DGL-4300
Is D-link DGL-4300 the only good gaming router? Do other companies make them?
PostPosted: Sat Jan 01, 2005 10:13 am
Team Member Top 100
Team Member Top 100
TsunamiZ wrote:
RickRock wrote:
D-link DGL-4300
D-Link is the only one I know of they uses a priority system when gaming.
PostPosted: Sat Jan 01, 2005 10:21 am
TsunamiZ wrote:
HoOdY wrote:
TsunamiZ wrote:
RickRock wrote:
D-link DGL-4300
Pssst....look at the picture dude. :wink:
PostPosted: Sat Jan 01, 2005 10:31 am
HoOdY wrote:
TsunamiZ wrote:
HoOdY wrote:
TsunamiZ wrote:
RickRock wrote:
D-link DGL-4300
So since it has an antenna and ports in the back, that means it supports both? I've never used a wireless router before.
PostPosted: Sat Jan 01, 2005 10:52 am
Team Member Top 100
Team Member Top 100
The Dlink has 10/100/1000 ports and supports up 108mb using a D-link compatible wireless card.
PostPosted: Sat Jan 01, 2005 11:19 am
Do Asus A7N8X-E and Abit AN7 mobos have compatible Ethernet support? Or do I need a seperate wireless card?
PostPosted: Sat Jan 01, 2005 7:28 pm
Team Member Top 100
Team Member Top 100
Just go and in a PCI wireless card and you'll be fine.
