It is currently Mon Apr 27, 2015 9:21 pm
 Post subject: Probably simple network setup question...
PostPosted: Wed Oct 13, 2004 5:11 pm
I have two custom built PC's with Netgear WG311 wireless PCI cards in them, an Apple iBook G4 with a built-in wireless NIC and an Apple Airport Extreme wireless router. I am able to get wireless connectivity without problems to all of the computers on the network. The problem is that now I am trying to secure my wireless network. I have gone into the Airport admin utility and have set up a 128bit WEP and created a password. I have told my two PC's to connect using that same exact password and they will not connect no matter how long it takes or what I try. I need some help on why they won't connect. The Mac (which is using the exact same password) works without a problem. I am not really a Mac user- it belongs to my roomate, so I am kind of flying blind with it. It's probably something simple, but I am having no luck. I have searched the forums but have come up empty. Any help would be appreciated. Thanks.
PostPosted: Wed Oct 13, 2004 5:20 pm
King of All Voodoo2 Cards
What operating systems?
PostPosted: Wed Oct 13, 2004 5:22 pm
The PC's have Windows XP SP2 and the Mac has OSX 10.3.5. Let me know if I've left anything else out.
PostPosted: Wed Oct 13, 2004 5:39 pm
Have you tried using the included Netgear software to connect rather then the Windows Zero Wireless Configuration Utility or are you already using the Netgear Software?
I only ask because I have more success with the software that came with my SMC, Oricnoco, and Linksys cards over the Windows Zero Wireless Configurator.
