It is currently Mon Apr 27, 2015 1:08 pm
 Post subject: using a wireless router with standard router
PostPosted: Thu Sep 30, 2004 6:56 am
Here's my delema....
I'll try and explain it as best as I can.
cable modem to [DLINK DI-704P] router.
That router has 2 computers plugged into it on ports 1 and 2.
Now, I also have a wireless router [DLINK DI-614+ Revision A]
- that I want to use to feed my laptop upstairs.
I disabled DHCP on the 704P and plugged an ethernet cable from port 4 of the 704P to port 1 of the DI-614+[wireless].
I enabled DHCP on the 614+.
On the laptop upstairs I assigned ip address corresponding to the 704P [i.e. 192.168.0.101 w/gateway 192.168.0.1]
notice I did not assign it the gateway of the 614+ which is 192.168.0.2
This configuration use to work, now it doesn't. Probably because I missed something.
Anyone have any thoughts on how I could get this kind of configuration to work, without telling me to buy an AP?
thanks
J-P
PostPosted: Thu Sep 30, 2004 3:35 pm
King of All Voodoo2 Cards
Are you plugging into the WAN port or the LAN port on the 614?
PostPosted: Thu Sep 30, 2004 4:55 pm
nope ...
plugged into port 4 of 614+
PostPosted: Fri Oct 01, 2004 6:53 am
Try rebooting everything (unplugging, then plugging in) the routers and the computers.
Have you upgraded anything to XP SP 2 recently?
PostPosted: Fri Oct 01, 2004 7:00 am
didn't upgrade yet...
uplug power, wait 2 mins, then reboot?
But is my set up correct?
PostPosted: Fri Oct 01, 2004 3:14 pm
I miss my [Ch]ams!
I miss my [Ch]ams!
I usually have DHCP enabled with NAT in the wired router plugged into the modem. Plug the wireless router into the the wired router and disable DHCP in the wireless router. You still need to give the wireless router an IP addy and subnet compatible with your network.
Eg.:
Broadband Modem --> Wired Router (192.168.1.1/255.255.255.0, NAT & DHCP On) --> Wireless Router (192.168.1.2/255.255.255.0, NAT & DHCP off).
PostPosted: Tue Oct 05, 2004 8:47 am
Chams is correct. I also think this topic has been discussed many times as well...
Depending on your router, you may want to plug the Ethernet from your WIRED router into the LAN port on your WIRELESS router (not the WAN port).
PostPosted: Thu Oct 07, 2004 12:50 am
Networking with a passion!
Are you running Zone Alarm? -it may be treating your trusted network as untrusted.
PostPosted: Fri Oct 08, 2004 8:29 am
Guys I'm wondering...
Should I buy an AP and plug that into the wired router
and save myself the bs??
PostPosted: Fri Oct 08, 2004 9:41 am
It couldn't hurt...
www.dalantech.com
PostPosted: Tue Oct 12, 2004 1:08 pm
That's what I did.
Whenever I'm not using the AP I just unplug it and I don't have to worry about the neighbors trying to crack my WEP or wardrivers sniffing around for some free access.
