It is currently Sun Apr 26, 2015 3:46 pm
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Tue Sep 28, 2004 7:55 pm
Ok, I'm looking for a final solution. Despite the costs of doing so, I think I'm going to make my USB Receiver (WUSB54G) obsolete and buy a PCI Receiver (WMP54GS). Then, I'll buy the High Gain Antenna kits for each (HGA7T and HGA7S).
That should be about $150. I wish I had bought the PCI Receiver in the beginning...
OC and g.m.waters, you think this will solve the problem? Or at least make it a much smaller problem?
PostPosted: Tue Sep 28, 2004 7:58 pm
Max [Ph]otographer
Max [Ph]otographer
I would buy the PCI reciever first, see how the connection is, then if you still need a better connection go for the high gain antenna kits.
A PCI reciever can be had for a lot less than $150
Edit: yeah, only about $60 for the reciever. That should get you about 300 feet indoors. ;)
Dan O.
PostPosted: Tue Sep 28, 2004 8:02 pm
Belboz99 wrote:
A PCI reciever can be had for a lot less than $150.
Dan O.
$150 for the whole get up. Probably about $50 for each component.
I agree though, I'll buy the PCI receiver first and then see if I need the antennas.
PostPosted: Tue Sep 28, 2004 8:05 pm
Celeron
Celeron
pdjkfc wrote:
The distance I'm working with is about at least 100 feet, you think this will work? I have a WRT54GS, are they compatible?
By the way, what is SMA?
Look at Linksys' website, www.linksys.com
i think it should have the WRT54GS listed as compatible.
SMA = well, i dont know what it stands for (google it) but it's the most popular type of connection jack between the antenna and the adapter.
PostPosted: Tue Sep 28, 2004 8:29 pm
I was just thinking, I'm only using USB 1.1. Do you think that's part of the problem? I understand why it would be slower, but would that contribute to it losing the signal?
Is the PCI Receiver still the better play?
Sorry for all the questions, I've just finally gotten sick of this. I've dealt with it for months now. Thanks guys.
PostPosted: Tue Sep 28, 2004 8:58 pm
1.1 for g speeds no, but for b speeds should work.
another thing you can try is a powered usb hub, you may not have enough power avail to fully power the usb device. especially if you have lots of usb devices, that draw power from the plug
 Post subject: WRT54G(router), WRE54G(Range Expander) and WMP54G (pci card)
PostPosted: Mon Feb 07, 2005 7:08 pm
Hi,
Just skimmed through the thread, your best best is to upgrade your USB to a Linksys wireless pci card (a lot faster). The hardware mentioned in the subject area is what I am using in a 2 story home and it is the bomb! I get a 54Mbps Excellent signal on my second floor wireless pc. To make this happen I just hooked up a WRE54G (Range Expander) today. I also added a set of HGA7T antenna to my router on the first floor. The setup wizard on the Range Expander cd did not work for me, so I had to set it up manually. It only took me 20 to 30 minutes to set up the range expander. It is not as hard as the reviews I have read and you do not need to bridge. The WRE54G does WORK!
