It is currently Sat Jan 31, 2015 10:07 am
 Post subject: Centrino (802.11b) and WPA ?
PostPosted: Sat Sep 18, 2004 7:15 pm
From my searches online it seems the Intel 2100 3B wireless controller (from Centrino) supports WPA. I am trying to get my laptop to use WPA with my Netgear WGR614 wireless router, but I don't know how. There's no mention of WPA in the wireless networking property tabs. I am running WinXP Pro SP1 (tried SP2, had some problems). I am pretty sure I have the WPA patch installed.
Do I need special drivers from Intel? this is a Gateway M505X laptop, centrino 1.4Ghz.
Right now I have WEP 128bit on. That and SSID suppression and MAC filtering should be enough for basic security, but it'll be cool if I can use WAP :D The router definitely supports it.
PostPosted: Thu Sep 30, 2004 3:43 pm
King of All Voodoo2 Cards
Your WiFi chipset needs to support it.
Usually a firmware update will do it. I updated my SMC 802.11b card and it has WPA support now.
