It is currently Sat Apr 18, 2015 9:31 am
 Post subject: Slow Server? Why?!?
PostPosted: Wed Sep 15, 2004 10:38 am
Hello,
I have a small server here the specs are:
P3 866MHz
512MB PC133 RAM
2x 160GB Maxtor HDD in RAID 1
Soyo 7VCA motherboard.
Netgear NIC
We are using a D-link 5 port switch.
The problem is when I open MS Access, it takes FOREVER!! Ok, it more like takes 1-2 minutes. Is this normal?
The above server also acts as a printer server. When I go to print from my computer (not the server), it also takes 1-2 minutes before it will start printing.
What can i do to speed these up?
Any help is appreciated. Thanks
PostPosted: Wed Sep 15, 2004 11:31 am
Where is it located? on the same LAN?
What is the NOS? Windoze?
PostPosted: Thu Sep 16, 2004 8:11 am
It is using Windows XP SP1 Pro as the OS. The server is on the same network as the other computers, all connected with the D-Link Router. I have 3 other computers on the same network.
PostPosted: Fri Sep 17, 2004 7:40 am
Do the hard drives turn off with power settings?
PostPosted: Fri Sep 17, 2004 11:55 am
Networking with a passion!
If the speed of your switch is 100 Mb/sec full duplex then make sure the NIC on the server is set to the same speed -don't really on "auto" for the speed and duplex settings, it doesn't always work.
www.dalantech.com
