It is currently Wed Apr 01, 2015 2:51 pm
 Post subject: question on cable modems
PostPosted: Mon Aug 02, 2004 12:45 pm
Hi all. I currently have a Linksys cable modem, Docsis 1.1, and I was wondering if there was much of a difference between it & a DOCSIS2.0 modem, such as the Toshiba PCX2600? Anyone know if there's any difference in performance/speed between 1.1 & 2.0?
TIA,
Bill
PostPosted: Tue Aug 03, 2004 3:25 pm
King of All Voodoo2 Cards
I upgraded from a 3Com CMX (1.0) to that fruity looking motorola Surfboard modem (2.0) and there was no speed difference between the two.
PostPosted: Tue Aug 03, 2004 3:55 pm
there shouldn't be any speed diffrences no matter what modem you goto, cos all ur speed and connection is all based on files sent to ur modem from ur isp, if u were to hack the cablemodem and change the files on it.. then u would need a modem to be able to do that.
PostPosted: Tue Aug 03, 2004 8:45 pm
As the above poster said, you wouldn't notice much of a difference at all. The real "bottleneck", if you have one, is going to be your ISP.
PostPosted: Sat Aug 28, 2004 8:39 am
I judge you GUILTY!
I judge you GUILTY!
I changed my cable modem to a Motorola Surboard 5100 from a Toshiba 1100.
While my download speed didn't change, my upload speed did.
Basically, a neglible difference. However the surboard has better LEDs and a Kill switch in case something bad happens.
PostPosted: Mon Aug 30, 2004 2:51 pm
Dude, it's about time you showed up here, have you been slumming around the old forum or just lurking in the background?
PostPosted: Mon Aug 30, 2004 10:41 pm
Getting a new cable modem can make a huge difference. I was getting Highspeed internet which was 3mbts down and 380kb/s up. I purchased a new modem for $80 and I now get 5mbts down, and 800kb/s up. That is basically doubled performance. By the way I use Rogers Cable. Great ISP in Canada.
