It is currently Sat Apr 18, 2015 1:11 pm
 Post subject: Linksys WAP with Netgear wireless router??????
PostPosted: Sat Aug 28, 2004 1:34 pm
Will I have any issues with compatibility? 4 computers, main system is hardwired to netgear router and the other 3 are connected with linksys wireless PCI cards (model #'s are not important). My question is will the Linksys WAP be ok to use in this situation or will it conflict with the netgear router?
thanks in advance
PostPosted: Sat Aug 28, 2004 2:14 pm
Celeron
Celeron
Probably, yes. if they use the same standard they should be compatible with each other.
PostPosted: Wed Sep 01, 2004 6:07 pm
Yeah, I don't see why not.
