It is currently Thu Jan 29, 2015 10:40 am
 Post subject: AIM router problems
PostPosted: Fri Aug 27, 2004 11:49 pm
this question has probably been answered before but here i go anyways
Im using AIM and my internet connection gets dropped when i try to run services like direct connect, talk, file send/receive etc.
what ports need to be opened in order for AIM to work properly as in #-# tcp and #-# udp
thanks
 Post subject: Re: AIM router problems
PostPosted: Sat Aug 28, 2004 2:20 am
From the AIM FAQ
PostPosted: Mon Aug 30, 2004 2:41 pm
King of All Voodoo2 Cards
In your AIM settings it's usually port 4443 and depending on the version of AIM you're running there's a checkbox that may need to be checked to use that port.
