It is currently Fri Jan 30, 2015 6:09 am
 Post subject: no internet connections
PostPosted: Fri Aug 27, 2004 6:00 pm
ipconfig shows all valid numbers, and be released and renewed, but cannot ping google or anything
also, the "set up a home or office network" does not finnish
win xp home
problem is that the computer cannot connect to the internet...what do you think i should do to make it able to connect?
PostPosted: Fri Aug 27, 2004 6:02 pm
What are the results of your ipcofnig /all
PostPosted: Fri Aug 27, 2004 8:11 pm
give your hardware specs and ill see what i can do help you out. do you have a router? firewall? etc.etc.etc. how many computers are connected to your network? do you have a cable modem? adsl?
 Post subject: Same trouble
PostPosted: Sun Sep 12, 2004 6:36 am
IMy problem is this, I can run "Network Wizard" and it runs fine closes down and reboots, however after this I can no longer conn to ISP, running Win ME with a D-Link Router for cable modem, I have done this 3X and get the same trouble.
Mott
PostPosted: Sun Sep 12, 2004 10:29 am
Still need more info to completely T-shoot...but when you say you are trying to ping a host, are you using the host name or the IP. You could possibly be having DNS problems.
try pinging one of Googles IPs: 216.239.57.99
If that works and pinging www.google.com doesn't. Then it could be (and most likely is) DNS related.
If you can't ping the IP, the try a traceroute and see where your packets are hitting the floor...[Windoze is tracert]
make sure you can at least hit your router.
PostPosted: Tue Sep 14, 2004 12:34 pm
have you tried pinging the IP addresses instead of the domain names? could be a DNS issue.
