It is currently Sat Apr 18, 2015 12:10 pm
 Post subject: Automated DHCP releasing for Linksys router.
PostPosted: Thu Aug 26, 2004 5:32 am
My brother is having problem with his router. He needs to release the DHCP setting periodically.
Is there a way to automatically release the DHCP setting on a Linksys router?
He's using Win 2003 Server. I don't know what particular model of Linksys router he has.
If there is an alternate solution that would also be great.
 Post subject: Re: Automated DHCP releasing for Linksys router.
PostPosted: Sat Aug 28, 2004 2:22 am
Why? What DHCP address does he need to release, the address from his ISP or addresses on the local LAN?
PostPosted: Sat Aug 28, 2004 3:51 am
I believe it's the IP address. The LAN is fine but he can't connect to the internet until he manually releases the DHCP in the routers browser.
I'm sorry I don't have more specific since this is my brothers problem.
I just figured if anybody else had a similar problem they would have an idea about how to remedy it.
PostPosted: Sat Sep 04, 2004 1:40 am
Set the WAN configuration to 1 day in the main configuration menu. Fairly straight forward.
PostPosted: Sat Sep 04, 2004 8:42 am
Well, that works if he only needs to set it up once a day.
The only solution I can think of is to write a perl script that issues the commands necessary. Linksys use web browsers for setup and configuration, so this would be straightforward ... for a perl scripter.
Otherwise, I would strongly suggest that your brother fix the problem rather than the symptom. Why does he need to release and renew his IP manually?
PostPosted: Sat Sep 04, 2004 6:44 pm
The script commands would have to be compatible with the firmware, would it not. If it's as easy as that, I'd love to be able to program my router.
Small ISP's with limited IP pools tend to be picky with their leases. Bell does this with their DSL...they'll kill it if there is inactivity for longer than a day but the service is still connected.
