It is currently Mon Apr 27, 2015 5:11 am
 Post subject: weird resolving issue
PostPosted: Fri Aug 20, 2004 11:56 am
this is what i've sent to the support at zoneedit.com:
I think I know what the prolem is. It seems that networks behind a
router cannot ping www.cigar3tte.com, but can ping cigar3tte.com.
I have tested this from 4 different locations, 3 of them are behind
routers and cannot ping www.cigar3tte.com, while the 4th one with no
router is able to ping fine. I'm assuming you are not behind a router
from where you pinged.
Using the diagnostics on the routers (2 locations) to do the pinging
seems to work.
Everything else seems fine though, so I do not see what the routers
could've done on the locations that failed to resolve
www.cigar3tte.com.
I've cleared the browser's cache, and do not see any effects.
the web server is on my home network, with a Windows 2003 Server running IIS 6, Domain Controller, DNS Server, DHCP, etc.
i have DirectUpdate service running on the server to refresh the dynamic IP to Zone Edit.
domain is registered with GoDaddy.com.
please help, this is really frustrating.
 Post subject: problem solved
PostPosted: Fri Aug 20, 2004 1:55 pm
nm, problem has been solved.
it appears that i needed to reconnect the program DirectUpdate for my new settings to take effect.
