It is currently Tue Jan 27, 2015 8:14 pm
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
 Post subject: Network security
PostPosted: Fri Aug 20, 2004 7:02 am
I am looking for an option for making our small businees network more secure.
What are some good options?
a seperate security/firewall router of some kind. Or just a firewall program on the server when we have one?
Currently we are just running a shared LAN off a router and and a cable internet line.
Thanks in advance.
PostPosted: Fri Aug 20, 2004 7:14 am
My personal opinion (which means nothing) would be to go with a hardware solution for a firewall.
Just my humble opinion. Better to go hardware in a business environment than bog down servers with more software.
PostPosted: Fri Aug 20, 2004 7:17 am
7yrs+11,000 Posts
7yrs+11,000 Posts
encrypt it
PostPosted: Fri Aug 20, 2004 3:50 pm
I agree with that as well...HW solutions are so reasonably priced nowadays.
I would probably actually run both...get a HW based solution and take the necessary precautions on the server side as well (maybe in the form of a FW)...and of couse on the server side, you'll have all the non-essential services turned off.
 Post subject: Re: Network security
PostPosted: Fri Aug 20, 2004 9:37 pm
Thanks in advance.
http://www.ipcop.org should suite all your needs. I've recommended it and set it up for small to medium businesses. With good anti-virus and e-mail administration you'll be as secure as you can be.
What is your current network like?
PostPosted: Sat Aug 21, 2004 9:44 am
definitely a good hardware firewall would be a good choice.
PostPosted: Fri Aug 27, 2004 8:15 am
Currently It is just a shared network between 8 comps (mostly win2kpro machines) in a small business.
One computer is hosting the database currently. When we move to a new building I will convert it over to a server/client based network with windows server for more control to data access and software firewall protection for the network. However till then i need something for more protection between our cable internet modem and our router. Maxpc had given a good review about a security box in the last couple issues but i can't seem to find it.
I just recently started to work here and I inherited the network as my own. So I am trying to make it better.
I have been looking at things like a Sonicwall SOHO3 or TZ170
or a WatchGuard Firebox SOHO6
All i need is something that can cover our current setup going out to 2 switches across the office
after the move it would run between the cable modem and the server running windows server with a software firewall . From the server I would have a multi-port nic to go to the switches.
PostPosted: Thu Sep 02, 2004 2:17 pm
Since this thread has been continued in a new thread here, I'm locking it.
