It is currently Fri Feb 27, 2015 5:03 pm
 Post subject: Help me buy a TWC-approved cable modem
PostPosted: Sat Apr 05, 2014 3:15 pm
Well, soon to be TWC-Comcast, anyway. :(
I'm probably going with TWC's 20/2 or 30/5 services, which are $45 and $55 before taxes and whatever fees they feel like tacking on after the fact.
Here's my list of TWC's compatible modems from the Ultimate-75 and Ultimate-100 plans:
https://docs.google.com/spreadsheet/ccc ... _web#gid=5
Here's their full list of approved cable modems:
http://www.timewarnercable.com/en/resid ... modem.html
Here's their full list of approved modems copied into a Google doc:
https://docs.google.com/document/d/1phx ... sp=sharing
I'm leaning towards 8x4 wired modems without routers included, namely the Zoom 5341J since it's the cheapest 8x4 router. I really won't use wireless that much in this particular scenario, and I want to keep the router and modem components separated so I can get the best of each world at this price tier (no FDR / 56GB cards here). I've got a wireless usb 1200ac router I can use as an access point anyway. So which ones have you had firsthand primary experience in benchmarking, or can link to reviews?
I've read that some modems are unusable if they're associated with a current account. Can anyone comment on or verify this?
 Post subject: Re: Help me buy a TWC-approved cable modem
PostPosted: Sat Apr 19, 2014 3:55 pm
Million Club
Million Club
Hi ya,
I recently went through this scenario myself with TWC. (about 2 months ago)
I was paying $65 for 20/2... and saw that if I jumped up 2 tiers to the fastest, 50/5 it was also $65. (Guess I was overpaying for quite some time)
Anyway.. I also decided to split out the 'modem' and the 'router' separately.
I bought the Zoom 5341J for a cable modem. In the past, I had tried a Motorola SBG6580 (combo modem/router) and it worked for about 10 weeks, until it started intermittently dropping connections and have to reboot once a week.
Anyway, I'm happy with my Zoom and have very reliable speeds. I couple that with a Linksys AC1900 (EA6900).
I was nervous though, as I'm normally a LinySys, Netgear, and D-link fan. I thought it was time for a change.
