It is currently Wed Apr 01, 2015 6:58 am
which equipment are you using and why
netgear 8%  8%  [ 2 ]
d-link 4%  4%  [ 1 ]
2wire 0%  0%  [ 0 ]
other - reply and tell what u got 8%  8%  [ 2 ]
linksys 79%  79%  [ 19 ]
Total votes : 24
 Post subject: which equipment and why
PostPosted: Mon Aug 16, 2004 8:14 pm
Which networking gear are you using and why?
PostPosted: Mon Aug 16, 2004 8:43 pm
im using linksys, just because of all the options
PostPosted: Mon Aug 16, 2004 9:44 pm
im usin linksys. my first router, someone recommended me it back then. never let me down yet and its working great.
 Post subject: Re: which equipment and why
PostPosted: Mon Aug 16, 2004 9:46 pm
Linksys. I've always loved their products, as I have never been disappointed with their stuff.
PostPosted: Tue Aug 17, 2004 7:16 am
I was using an SMC Marricade....until that crapped out..haven't replaced that yet...probably won't for a while as I have no need. The adapter I have is built in with a 4 port and seems to be working for what I'm doing.
PostPosted: Tue Aug 17, 2004 9:37 am
Netgear router, onboard gigabit nic. Netgear because it was cheap :)
PostPosted: Tue Aug 17, 2004 11:51 am
King of All Voodoo2 Cards
Been using Linksys and 3Com since 1995.
Aviod D-Link like a hooker with an STD.
PostPosted: Wed Aug 18, 2004 8:31 am
Got an original Linksys BEFSR41 when they first came out.
...Of course it was close to 2 years before it and my ADSL worked together.
No other problems with the thing, though for some reason it has started locking up once every week or two in the last few months. Maybe it's crapping out finally..
<=T=
PostPosted: Wed Aug 18, 2004 12:09 pm
I've been using Dlink now for 7 years...main reason for me is asthetics...In order to best reach all the areas of my house (via wireless) I need to place my CPE in the kitchen...so I wanted the smallest, best looking, best matching equip I could find...both times, it was Dlink.
I'm sure most manus do this now, but the 108Mbps wireless was a must also.
PostPosted: Thu Aug 19, 2004 5:46 am
From what ive seen linksys has the best antennas, although i might be moving to apple airport soon. I actually switched from my linksys to netgear a while ago and i had to put the antennas from the Linksys onto the netgear just to get a decent signal. Although you can't do that with the Netgear G router:(
PostPosted: Thu Aug 19, 2004 11:44 pm
I use a Linksys BESFR41 router as my core switch at the moment. I am using an IPCOP router http://www.ipcop.org as my boundary device and it works beautifully. Before that my Linksys worked flawless EXCEPT for VPN connections. The IPCOP support VPN connections without a hitch, which is just another reason why I'm using it (next to it's native IPTABLE firewall, and the fact it's probably the most configurable, and free solution out there).
Anyway...my NIC's are Linksys, except for the IPCOP machine which has one netgear 10baseT card for the IPCOP red interface. Keeping your vendor's in line can help with standards compatibility problems, especially in wireless products.
PostPosted: Sat Aug 21, 2004 3:12 am
Solid as a rock
Solid as a rock
Linksys. I had it for the past year. I tested a Dlink and quickly switched back.
PostPosted: Sat Aug 21, 2004 3:59 am
I'm using a Linksys BEFSR41 V1 router that I've had for about five years, because it still works.
PostPosted: Wed Sep 01, 2004 10:11 am
Linksys,
Just a good name and at the time got 45.00 off and a 10% discount
Never had a problem with it.
PostPosted: Wed Sep 01, 2004 2:25 pm
Anyone know what happened to 3Com?
Did they pull out of the business or are they only making integrated NIC chips from now on? They don't seem to be mainstream anymore or mentioned in any hardware news.
PostPosted: Wed Sep 01, 2004 2:50 pm
In the lab!
In the lab!
Dlink cards and a linksys wap...
PostPosted: Sun Oct 10, 2004 8:38 pm
Hehe, I have a D-link DI-604. Good router after I flashed it.
Before that..
If I had it to do all over again I would have chosen Cisco/Linksys
