It is currently Sat Apr 18, 2015 11:32 am
 Post subject: WiFi Antenna gain
PostPosted: Mon Aug 16, 2004 3:50 pm
I was wondering if anyone had info on the dBi range of the WiFi extenders. i know that the gain is different because of trees, rocks and the like, but i would like a relative figure on 2dBi - 18+dBi.
PostPosted: Mon Aug 16, 2004 4:06 pm
King of All Voodoo2 Cards
Antenna gain by itself is a useless figure without the amount of power your adapter/AP is putting out.
If you want a solid figure, get your Antenna's Gain and your Adapter/AP's power output and consult the following chart:
http://www.fab-corp.com/db.htm
PostPosted: Sat Aug 21, 2004 10:17 am
Make sure it's large enough to knock out all wireless signals for 50 miles and make it from pringles cans hahahahaa
