It is currently Sun Feb 01, 2015 3:31 pm
 Post subject: Wireless System Requirements
PostPosted: Fri Aug 13, 2004 9:29 am
I am going to buy a Wireless-G PCI adapter for my computer and was wondering if wireless is compatible with windows 98 first edition because I know it is with the second edition.
PostPosted: Fri Aug 13, 2004 6:29 pm
Sure. Why not. :)
Check to see if the router has drivers for that OS. If it does, you have support. If it doesn't, you're out of luck.
PostPosted: Fri Aug 13, 2004 6:46 pm
Professional Dork
Professional Dork
READ THIS OR GET BANNED.
I won't tell you again.
