It is currently Tue Mar 03, 2015 3:25 am
 Post subject: How do I kill the WAN on a Linksys WRT54G?
PostPosted: Wed Aug 11, 2004 2:12 pm
First my "network" consists of only one computer behind the WRT54G and then my cable modem.
I'm trying to totally disable my WAN until I want to manually activate it.
I've disabled the WAN in the HTML interface to the router. As an added percaution, The MAC filter is set to a blank whitelist. Firmware is up-to-date.
However, my WAN light is STILL on (no traffic). Linksys tech support is offsourced it seems and of no help. Any suggestions for this n00b?
Thanks.
PostPosted: Wed Aug 11, 2004 2:27 pm
King of All Voodoo2 Cards
Can you be a little more specific, because I can't tell if you're trying to disable your Internet Connection (WAN), or the wireless part of your router.
If you're trying to disable the WAN, just unplug it from the cable modem.
If you're trying to disable the Wi-Fi, there should be an option on the Setup page within the router to turn off the wireless. I just saw it yesterday on a Linksys router I was working on for a friend, it's about halfway down on the first page, set Wireless to disable.
PostPosted: Wed Aug 11, 2004 3:04 pm
My apologies, I got my acronyms crossed.
I want to disable the wi-fi part of my router. I've tried what that Linksys documentation has said to do, and it has worked before---but after unplugging the power to protect my network from lightning I can not seem to disable it from the HTML interface.
PostPosted: Wed Aug 11, 2004 3:09 pm
PS: It does say Disabled and I have saved changes....but does not indicate it on the router itself because the WLAN is a steady green.
PostPosted: Wed Aug 11, 2004 7:03 pm
Do you have a WiFi card you can test it with? or a friend with a WiFi card you can test it with?
 Post subject: WRT54G
PostPosted: Wed Aug 11, 2004 9:56 pm
http://192.168.1.1
Password Default: Admin
Then go to Wirless Menu, and put on Wireless Network Mode and on SSID Broadcast: Disable.
GALLO
PostPosted: Wed Aug 11, 2004 10:31 pm
it kills it if you hit disable....i have a linksys and wireless computer
