It is currently Tue May 21, 2013 2:23 pm
 Post subject: Ethernet Cable
PostPosted: Sun Apr 22, 2012 1:10 pm
Are all Ethernet cables pretty much the same, I mean like speed and quality. I am going to get a 50ft cable and just want to know if there is a difference between a cable that cost $25.00 and a cable that cost $12.00. Thanks.
 Post subject: Re: Ethernet Cable
PostPosted: Wed Apr 25, 2012 7:48 am
As long as you're buying a Cat5 or Cat6 cable, there won't be any difference.
PostPosted: Fri Apr 27, 2012 1:45 am
Cat 5e for 10/100/1000MB network, Cat 6 if you want to run very long gigabit runs (100ft +) or want something that'll last through 10 GigE. Don't buy into the "Premium" cable crap. Just a regular Cat 5e cable will be fine for all but a very few home networks. And just in case you see something about 300MHz or 500MHz cable, safe to ignore it for most applications.
PostPosted: Sun May 06, 2012 6:32 pm
Just a regular Cat 5e cable will be fine for all. I don't have trouble with these.
