It is currently Fri May 24, 2013 2:21 am
 Post subject: Shareaza ports
PostPosted: Wed Apr 04, 2012 6:36 pm
I think I've done all I can do to open port to computer. I've went to router to open port with the computer's IP. I also went to the computer and created a static IP. Made sure the firewall well accept UDP and TCP on that port. I've used Portforward.com's port checker to check if the port is open. And it says port is open. But cannot ping router.When I try to use Shareaza's connection test to see if the port is working. It says it did not pass. So I'm confused as to what to do now. Any help welcome. Thank you.
 Post subject: Re: Shareaza ports
PostPosted: Wed Apr 04, 2012 7:47 pm
I had this same problem a while back. I had to enable UPnP in my Linksys WRT54GS's Administration -> Management page, and to "Enable UPnP connection devices setup" in Shareaza. Everything else except static DNS servers in the router was left on full automatic.
PostPosted: Wed Apr 04, 2012 9:22 pm
Thanks for the quick reply and for your help. :) Will do it as soon as a I can. Thank you.
PostPosted: Thu Apr 05, 2012 9:00 pm
If you have any trouble even after doing this, uncheck the Random box and enter 6436 instead of 0 in that Port box marked "Inbound Address", click Apply, Ok, close Shareaza and restart it.
PostPosted: Fri Apr 06, 2012 7:56 pm
Read more about UPnP and decide I not to use it. I would probably make it easier to setup but not worth the secruity hassle. But thanks for the help though. :)
PostPosted: Fri Apr 06, 2012 9:25 pm
Ah, c'mon, give it a shot. :D
Read this: http://networking.nitecruzr.net/2006/01 ... sk-or.html
Or... turn OFF UPnP in both Shareaza and your router after you set up that port number as mentioned above. I just tried it myself and Shareaza works just fine.
PostPosted: Sat Apr 07, 2012 12:19 am
I know Shareaza is using the port though. Which is strange. I checked which network I'm on and two servers are using the port. It's just when I test out the port on Shareaza, it's not passing it. I'll really have to think really hard about it.
