It is currently Tue May 21, 2013 8:51 am
 Post subject: router-level restriction on printer access?
PostPosted: Sat Feb 04, 2012 10:51 am
I have a small home network that I use primarily to share internet access among three computers, each one used by a different person. I just rearranged my own setup and it made more sense to move my printer onto the router instead of plugging directly into my machine as I had been doing for a few years.
What I want to do now is restrict access at the router so only my computer can use that printer. How do I go about it? All the help info I have found online deal with modifying network settings at the user or group level within windows 7.
Printer is a Canon MP970, router is a D-Link DIR-655.
 Post subject: Re: router-level restriction on printer access?
PostPosted: Sat Feb 04, 2012 12:19 pm
Why can't you just keep it plugged into your computer? This is the simplest way to get the behavior you want.
PostPosted: Wed Apr 18, 2012 1:42 pm
On the web interface for the router, go to the "Advanced" tab and click on the "SECURESPOT" link on the side. In the "Info" area there should be a link to configure the service, which should include access controls.
