It is currently Sun Mar 01, 2015 7:55 pm
 Post subject: Changing routers and have a problem
PostPosted: Mon Dec 26, 2011 9:51 pm
Million Club - 20 Plus
I've never had to do this before. Coming here for direction.
My sister replaced her router after the wall wort had a nuclear meltdown. But there is a 'problem'.
Her internet service modem they provide wants to be 192.168.0.1 and the router wants to be the same.
How do I change the router to 192.168.1.1??
I've never had this 'conflict' before so I've never even thought about what I would need to do.
 Post subject: Re: Changing routers and have a problem
PostPosted: Mon Dec 26, 2011 11:14 pm
For my router (WNDR 3700), you can change the LAN IP address (it's under "LAN Setup"), try looking for something similar. What router do you have?
PostPosted: Tue Dec 27, 2011 8:10 am
You'll also have to change the DHCP pool to addresses in the same range. That setting shouldn't be too far from the LAN address.
PostPosted: Tue Dec 27, 2011 10:45 am
Netgear DIR-655
PostPosted: Tue Dec 27, 2011 11:27 am
dedgar wrote:
Netgear DIR-655
I'm assuming you mean D-LINK.
Assuming you haven't registered for SecureSpot.
Go to "Setup" then "Network Settings". Change "Router IP Address" to "192.168.1.1", then change "DHCP IP Address Range" to "192.168.1.x" and "192.168.1.y", where x and y are your DHCP address ranges.
Who knew that D-LINK has emulators for many of their routers? Also the SecureSpot looks interesting.
PostPosted: Tue Dec 27, 2011 2:47 pm
Yes I meant D-Link. Was even staring at the box. (facepalm)
