It is currently Thu Feb 26, 2015 10:23 pm
 Post subject: Need help with choosing a DD-WRT build for Linksys router
PostPosted: Mon Oct 03, 2011 8:21 am
I have an old Linksys WRT350N v1.0 wireless-N (actually draft-N, since it came out before the wireless-N standard was finalized) that I am looking to flash with DD-WRT. However, in doing my due diligence in researching this firmware, I am finding a number of pitfalls and confusing information concerning the build that I should use for flashing this router's firmware. It appears that the most stable version has issues and the newer versions that are available for this router are not necessarily better. I would like to know if anyone here has had any experience with this problem and, if so, what build they would recommend for this particular router. The reason that I am looking into this is because the latest available firmware update from Linksys was either three or four years ago, and am thinking that I can improve its performance with DD-WRT. Any and all suggestions are greatly appreciated.
 Post subject: Re: Need help with choosing a DD-WRT build for Linksys route
PostPosted: Mon Oct 03, 2011 11:53 am
I always try to get the latest version. It should be this one here. You would have to look into USB support. Not sure if it works for your model. And of course the peacock thread.
