It is currently Sun Mar 29, 2015 8:39 am
 Post subject: Netgear N750 (WUNDR 4000)
PostPosted: Fri Aug 05, 2011 10:59 am
Anyone have any experience with this router? I just picked it up for use with my theater, but am a little confused.
What are the best settings for it if I don't plan on using the wireless for my AVR setup?
 Post subject: Re: Netgear N750 (WUNDR 4000)
PostPosted: Wed Oct 26, 2011 12:10 pm
If you have a N wireless Network make sure you are using WPA2 / AES encryption and 20/40 or Auto signal
Other than that you can leave the defaults and setup whatever SSID you want. Also make sure you change the default password from admin / password.
Default IP should be 192.168.1.1
