If you have wire drop points around the home, then all you need to do is configure additional WAPs (wireless access points) and patch them to those wire drop points. Although you can buy standalone WAPs for this purpose, many ppl instead use wireless routers since they tend to offer the best deal. If you do, then you’ll need to disable DHCP on those additional routers, and assign each a unique, static IP in the same subnet as the primary router. So let's say the primary router is using 192.168.1.1. Then perhaps make each additional WAP the next in succession (192.168.1.2, 192.168.1.3, etc.). Whatever IP scheme you use, just make sure it doesn't overlap the IPs allocated by the primary router's DHCP server. Of course, each should be using a different wireless frequency. You then patch them to your wire drop points over a LAN port (the WAN port is never used, so you don’t need to be concerned about routing, NAT, firewalls, etc., which are only relevant to the WAN port). Finally, if you prefer, you can give the primary router and all additional WAPs the same SSID and wireless security settings. That way you'll have some roaming capabilities and not require reconfiguration of your clients each time some laptop or other portable device is moved.
