It is currently Thu May 07, 2015 12:50 am
 Post subject: network+network
PostPosted: Mon Feb 07, 2005 6:06 pm
I want to know how to add a small network to another small net work.
Heres the deal:
I have a wireless home network, with my family computer area being the center of it and that has the DSL line and wireless router, i am trying to set up a small wired network in my room, the only comuter on the familys wireless network is my main computer, i have a few old ones laying around that i want to network, i want to use my main computer with the wireless card in it to be the internet access for my new network
can i do this
and how
what i was thinking:
buying a hub and some cables and setting up a small network in my room and sharing the internet connection from my mian computer
thanks so much
BTW-I want to add the other computers and give them net access so i can get them folding
PostPosted: Mon Feb 07, 2005 7:08 pm
i don't think you need to buy another hub/switch/router, you just need to program your router to accept 2 different subnet. That is exactly what subnet masks are for (breaking up a network into smaller networks).
PostPosted: Mon Feb 07, 2005 7:13 pm
my problem is that i can not wire the computers to the router, and i dont want to spend all that money to buy each computer a wireless card
PostPosted: Mon Feb 07, 2005 10:07 pm
you cant have your cake and eat it to. one way or another you have to connect to something. if you already have wireless, the cheapest way to go is refurbished usb keys, i get mine at frys for under 20
PostPosted: Tue Feb 08, 2005 5:39 am
what do you mean USB key, like those wireless USB adapters?
PostPosted: Tue Feb 08, 2005 5:51 am
what i want to go is make a wired net work in my room and share the internet connection from my main computer that is on the wireless network
How do I do this?
PostPosted: Tue Feb 08, 2005 5:52 am
exactly, i get them from frys refurbed for 19.00, they are on outpost right now for that price
i would link it but its long.
you would need a router or switch for the second network, and to use your machine as the connectionto the net.
you will have to buy something, i would get 1 wireless key and use it on all the machines, switching to the next one to write, they will be slow folders you will have lots of time. the cheapest is of course sneakernet, manually moving the files to a connected machine to send results.
PostPosted: Tue Feb 08, 2005 2:25 pm
Folding Momerator
Folding Momerator
What mobo do you have? Do you have the lan port on it as well as the wireless?
PostPosted: Tue Feb 08, 2005 5:26 pm
i do have two lan ports(on mobo), and a 802.11g card, i have MSI K8N neo2 platinum
PostPosted: Tue Feb 08, 2005 5:27 pm
i yeah i forgot to add all the computers in my room that i want to network all have NIC's execpt for one, witch does not even work
