It is currently Fri Jan 30, 2015 3:37 am
 Post subject: Wireless Networking
PostPosted: Mon Feb 07, 2005 4:32 pm
Team Member Top 100
Team Member Top 100
Since SP2 windows has it wireless network wizard. THe only problem is that it detects all the networks in my building, is there a way for it to say only my network, and now show me the rest of the ones in the area?
PostPosted: Mon Feb 07, 2005 5:14 pm
King of All Voodoo2 Cards
The Windows Wireless Zero Configuration tool is utter crap. Disable it and stick with whatever came with your card.
PostPosted: Tue Feb 08, 2005 1:32 pm
Team Member Top 100
Team Member Top 100
To be honest it works fine, I got the belkin g router and it didnt come with software, you put the disk in and u can do things like set the SSID and stuff like that, but thats about it. I just want it to were my laptop can only "see" my router not anyone elses.
PostPosted: Wed Feb 09, 2005 1:27 pm
I'll give you an example: both the SMC software and the Linksys software that came with my cards allow me to enter an SSID and the cards will then only look for APs with that one SSID.
If I get a spare minute at work I'll show you what to look for with a screenshot.
PostPosted: Wed Feb 09, 2005 3:05 pm
Team Member Top 100
Team Member Top 100
Thanks, also is there a a program that will let me see whos all on my connection?
PostPosted: Wed Feb 09, 2005 4:27 pm
There's a program called Retina Security Scanner that I use that will tell you everything about every device on your network. Unfortunately it's not free :(
I've yet to find a free alternative.
that's an intrusion detection function, airsnare is simple and free for windows. You just create a safe list of your known mac addresses and it warns when unknowns are detected
PostPosted: Wed Feb 09, 2005 4:43 pm
Wow.
Airsnare has gotten a lot cooler since the last time I looked at it. I'm going to have to check out the new version.
