It is currently Mon Apr 27, 2015 11:27 am
 Post subject: Switching phone jacks to main line.
PostPosted: Sun Feb 06, 2005 3:19 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
Ok a few year ago back in the dialup ages we added a line so we could receive phone calls and be on the internet. Now, after we got cable we canceled the 2nd line. Now a few phone jacks in my house are pointing towards the non existent 2nd line. Is there a way I can switch them to the main line myself?
PostPosted: Sun Feb 06, 2005 5:29 pm
you have to look at your main line wiring at an existing jack and use the same pair on your 2nd line. If both pairs are wired, the center two is your main so just swap the inner pair with the outer pair on the 2nd line jacks.
If you are lucky, you have cat5 wiring and can use that for your home networking! But that is if your place is less than ~7 years old or so. Older wiring schemes use the 4-wire phone cable.
PostPosted: Sun Feb 06, 2005 5:35 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
ehh my house is 50+ years old. I may just be stupid, but i dont understand what you are saying.........
 Post subject: Re: Switching phone jacks to main line.
PostPosted: Mon Feb 07, 2005 12:37 am
ya open up the phone jack. you should see four colored wires (red,green, yellow, and black???). i cna't remember which colors, but two are for your main line and two are for your second line. swap the sets of wires.
POTS (Plain old telephone system) needs only 2 of the 4 wires in the phone cord. If you look closely at the phone cord end and the jack opening (where the phone cord goes) you should see where the wires should match up. It's really easy to figure out. And yes, you should definitely do this urself since it would be rather costly to have the telephone guy come and do it.
PostPosted: Mon Feb 07, 2005 2:54 am
Folding Momerator
Folding Momerator
Gamer, you can do it, it isn't hard, trust me, even I can do this.
PostPosted: Mon Feb 07, 2005 4:11 am
7yrs+11,000 Posts
7yrs+11,000 Posts
ok fine. lol. And i have a phone jack that dosent work at all...........
PostPosted: Mon Feb 07, 2005 3:25 pm
7yrs+11,000 Posts
7yrs+11,000 Posts
There are only 4 outer.
PostPosted: Mon Feb 07, 2005 4:26 pm
Most likely, when they installed your new line, they also installed a new punchdown block. This will most likely be in the basement (if you have one of course). you should be able to see both (the old and the new) next to each other.
The punchown is simply a corss-connect point where the phone company runs the 2-wire service into your house and then cross-connect all your phones to that service.
If you look at it carefully (like the others have said) you should be able to see how they connected the lines...remove the copper pair from the new punchdown and reterminate it onto the punchdown your main line resides on...
or you can try the other two pair run directly to the jack(like mentioned above).that's even easier...it really depends on how they installed your second line.
PostPosted: Mon Feb 07, 2005 4:58 pm
King of All Voodoo2 Cards
The Red and the Green should be Line #1
The Yellow and the Black should be Line #2
PostPosted: Tue Feb 08, 2005 10:50 am
BAM, there ya go! :D
