It is currently Sun Mar 01, 2015 11:56 am
 Post subject: Terminal Services Help
PostPosted: Fri Feb 04, 2005 5:04 pm
I've got to network two offices across town, the software needs to use terminal services and not VPN.
Can anyone give me some info or links on TS. I've got to get this together for them. And I'll have to learn how to set it up.
Thanks
PostPosted: Fri Feb 04, 2005 5:22 pm
Million Club - 5 Plus*
On Windows XP Pro
Control Panel... System... Remote tab... Check bottom box (Allow users to remotely connect to this computer)
If you want to make it more secure, you could tunnel it through an SSH connection.
Sites:
http://www.ece.utexas.edu/~luo/tightvnc_ssh.html
http://www.engr.wisc.edu/computing/best ... putty.html
Instead of VNC, enable TS, and forward port 3389 instead
PostPosted: Fri Feb 04, 2005 10:10 pm
Thanks, I have to get this together and implement it.
