It is currently Fri Jan 30, 2015 1:39 pm
 Post subject: A noob's question of WinXP Pro and a hub
PostPosted: Fri Feb 04, 2005 1:49 am
Okie, I'm a noob in networking. So how do I connect 3 WinXP Pro machine with a hub? :oops:
PostPosted: Fri Feb 04, 2005 5:08 am
plug 'em in, if there is no DHCP server or home router they will be 169.254.x.x
for details check out the FAQ "Setting up a basic network"
PostPosted: Fri Feb 04, 2005 5:51 am
I'm thinking we need to put some HOWTO stickys together for this forum...we get alot of the same questions over and over.
PostPosted: Fri Feb 04, 2005 5:44 pm
Simple thing you can do...
Instea of farting around with a DHCP server, Assign each machine the following...
Machine 1
IP: 192.168.0.1
Subnet Mask: 255.255.255.0
Machine 2
192.168.0.2
Machine 2
192.168.0.3
Then plug them on. At that point, you should be just looking at having the machines chatter at each other for a sec to show up in the Network Neighbothoof or you can just hit them by IP via a \\192.168.0.X (whatever machine you want to hit)
You could also poke through the XP CD, and install NetBEUI on each machine and just plug them on. A little more work if you ask me. You may also want to setup user accounts on each machine for the individual users o make file sharing a little less thought proviking.
