It is currently Tue Jan 27, 2015 5:37 am
 Post subject: capping net speeds
PostPosted: Wed Jan 12, 2011 3:49 pm
hi guys i want to cap the speeds of my sister net access. to something like ~100kb/s she is on the wi-fi network which is share by myself(PC and PS3), her and my dad. her and i have PCE-N13 300Mbps adapters while dad has some tp-link that also 300 Mbps. the wireless router is from belkin. thanks
 Post subject: Re: capping net speeds
PostPosted: Wed Jan 12, 2011 5:58 pm
if the router has QoS then you can mess with it there to limit the speed of her downloads.
i'd punch you however if you capped my downloads without telling me :D
PostPosted: Wed Jan 12, 2011 11:57 pm
i dont see any qos options on the router set up page
PostPosted: Thu Jan 13, 2011 1:11 am
you can check dd-wrt's router compatibility page and see if your router can be flashed to DD-WRT it has QoS (and a bunch of other stuff)
you could i suppose also buy a new router w/ QoS or one compatible w/ DD-WRT
or you could set up an old computer as a pfsense or monowall box to get more advanced routing options
As you can see here dd-wrt has QoS and you can also see i'm not using it currently :D
Uploaded with ImageShack.us
you could also try talking to your sister and see if you can figure something out :D
