It is currently Sun May 19, 2013 5:59 pm
 Post subject: sharing folder/files problem
PostPosted: Sun Sep 12, 2010 11:41 am
I have 3 computer at home with shared folders and files and have no problem.
now I installed a new computer No.4 and shared some folders.
the problem is that the new PC see all the shared folders from others computers
but the other computers, they see the computer in the workgroup and see all
the shared folders but when I trying to accesses one of the folders it give me this error message:
"" XXXX is not accessible. you might not have permission to use this network recourse.
contact the administrator of the server to find out if you have access permission.
Not enough server storage is available to process this command. "
All the computer run WinXP PRO with all the latest updates.
all computers have the same network group and connected to the same switch.
On the new computer the fire wall is off( I had to try this way. still no sharing)
Please help
 Post subject: Re: sharing folder/files problem
PostPosted: Wed Sep 15, 2010 12:18 am
wow,four computer work together,you may need special software to share files
PostPosted: Wed Sep 15, 2010 5:36 am
Team Dino
Team Dino
What OS is on each system?
n0b0dykn0ws
PostPosted: Fri Sep 17, 2010 12:47 pm
n0b0dykn0ws
all systems run WinXP PRO. the last computer i turn the firewall off.
I did a simple file sharing
PostPosted: Sat Sep 18, 2010 2:11 pm
Team Dino
Team Dino
Have you checked folder permissions?
n0b0dykn0ws
PostPosted: Mon Sep 20, 2010 10:48 am
n0b0dykn0ws
how I do that???
PostPosted: Tue Sep 21, 2010 6:16 am
Team Dino
Team Dino
On any directories you want to share, right click and select Sharing and Security then click the Permissions button.
At a minimum there should be Everyone with the Read box checked.
Do you see that?
n0b0dykn0ws
