It is currently Tue May 21, 2013 3:27 pm
 Post subject: router breaking Livestream, please help
PostPosted: Sat Sep 04, 2010 11:24 am
I've been setting up a room for a friend of mine, and she has three devices that need to be connected to the internet (laptop, desktop and an x-box 360). We've used a 'D-Link DIR-825 Xtreme N Dual Band Gigabit Router' to use for the purpose. She doesn't actually need to network these things together, but I was recommended to get a router to use to split the internet connection between them.
Everything seems to be working all right, except that we can't get the connected computers (laptop or desktop) to connect properly to Livestream sites (http://www.livestream.com/). We figure it has to be the router that's the problem, because if we remove it and connect one of the computers directly to the modem, the sites with Livestream content work fine.. it's only when the routers in place that they refuse to work.
I've looked all over this, and other help sites to find some kind of solution to this problem, but so far nothing has worked. I tried port forwarding the suggested ports (80 and 1935), but it didn't do anything.
If anyone can suggest something, or offer advice, I'd greatly appreciate it!
Thanks
 Post subject: Re: router breaking Livestream, please help
PostPosted: Sat Sep 25, 2010 6:54 am
Are you attempting to use Livestream as an end-user, i.e., someone who's just accessing the streams they provide for your own viewing pleasure, OR, trying to make your own Livestream content available behind the router available to others on the Internet? If it's the former, then no port forwarding is necessary. Port forwarding would typically only be necessary for the latter, when YOU are the content provider.
In fact, the Livestream content on their homepage is just using Adobe Flash Player, so that shouldn’t be a problem unless you’re having problems w/ Adobe Flash Player on other websites as well.
