It is currently Sat May 25, 2013 8:03 am
 Post subject: External hard drive or NAS setup question
PostPosted: Fri Aug 20, 2010 6:58 am
OK Guys/Gals I could use some Help,
I have two desktops and I have quick books pro installed on my wife's computer, she takes care of all of the receipts/payments.
I do all the estimates and invoices. Every time I need to do my work, I have to wait until she is done using here computer. Since she does allot of other work on her comp, it has become inconvenient to wait for her to finish her work, So I can do mine.
I was thinking of an external hard drive that I can plug each comp into it, but all the ones I have found only has one output-sata or usb. Then I thought I could find one that would hook into my wireless router and network it together that way, but there is no ext hd that has a Ethernet output.
The only other thing I can think of is a NAS network storage from newegg
Anyone have any other ideas or options?
If so could you please drop a link to your suggested recommendation?
Thanks
Ken
 Post subject: Re: External hard drive or NAS setup question
PostPosted: Fri Aug 20, 2010 7:48 am
Million Club 2+ [PC]*
What you really need isn't going to be as easy as setting up a NAS or EXT hard drive.
You NEED to have a dedicated server box. It doesn't have to be all that great of one either. Dual core CPU, 2GB ram, 500GB HDD, integrated graphics and you're on your way. You'll need a copy of Windows Home Server of some flavor. You could use one of your desktops as the server if money is tight. But I prefer not to perform daily tasks on a server/working box. Ideally, you want that server box sitting out of the way and only touching it when installing programs and doing updates.
Once the server box is set up, you install Quickbooks Pro on the server as a server install. I don't know anything about QBPro, but I would imagine it's capable of running on a server and being accessed by two or more other terminal computers, ie...the desktops you are currently using.
Since this is a business computer setup, you NEED to have at least these two other items.
1. A good, name brand UPS device.
a. CyberPower CP850AVRLCD This would be good for a desktop with monitor, back up hard drive and other small devices. You at least want your Server box plugged into one of these.
b. CyberPower Intelligent LCD UPS CP1500AVRLCD Or you could go with this one and run not only your server box, but your other two computers as well. As long as one of those other computers isn't a gaming powerhouse!
c. Whatever brand or model you decide to buy, make sure it has AVR (Automatic Voltage Regulation). AVR will help during brown outs, blackouts or over-voltage due to power station fluctuations or lightening strikes to sub-stations, etc. Also, note that a True or Pure Sine Wave UPS is more expensive and a better option on a UPS. However, most decent, good quality UPS's will use a modified square wave output. This is OK and is much less expensive. I use this type in my own home and I've saved my computers at least once for sure. A carpet cleaning van struck a power pole which had one of the streets main transformers mounted to it. As a result, the whole damned neighborhood went off/on/off/surged back on then off for good. All of my electronics are UPS protected and I didn't lose anything. However, the guy across the street had to file a home owners insurance claim because his brand new Mac desktop and brand new, two day old Mac laptop got badly damaged. Along with his expensive LaserJet Color printer. NEVER plug a printer into a UPS with your computer on it. Use a high quality power strip for that. Printers, especially lasers, have a very high peak start-up voltage that can, at best, shut off your UPS. At worst, it will fry your new UPS.
2. You will need a good backup solution that is external of your server box. You sure wouldn't want to lose your data!! That would really suck come time for taxes. Seagate's Blackarmor products are outstanding. The backup and scheduling software they come with is, IMHO, the best you can get for running a business.
3. A NAS or backup device alone will not allow you to both access the same program at the same time. So you will still be stuck waiting for your wife to get off the computer so you can input your data into QBPro.
4. You will either need to make a thread here asking for all kinds of advice on how to set up a home server, buy a book telling you how to do it, research on the Internet or, my suggested option, hire an IT guy to get you setup and running. After that, you won't really need an IT guy any more as long as you know how to do basic OS and program updates.
I hope it all works out for you soon. I know there are cheap boxes from HP, Compaq and the like that are already setup to be a home server. I'm just not sure how suitable they would be to a business environment. Dell has a pretty good system as well for the home business and their technical support, once you get through to them, are pretty decent in telling you how to get some of the things setup. Still, you will need to figure out how to properly install QBPro and I know Quickbooks technical assistance can cost you some $$$ to help you out.
Good luck! I'm sure others will swing by with other advice for you.
PostPosted: Fri Aug 20, 2010 8:29 am
By Design, you'd be unable to mount a USB drive by more then one computer at a time.
That leaves you with a network solution be it the NAS you mentioned or file sharing...
If you go with the NAS, you're not going to find one with a wireless device, so you'd have to use something like a wireless gaming adadpter to connect it . Considering the expense, you may be better served getting a windows home machine with a wireless card
As a suggestion, I'd probably go with the file sharing for now to research multiple users using the same file within quickbooks. It doesn't make sense to deal with anything else until you're certain you can do that.
PostPosted: Fri Aug 20, 2010 9:23 am
Thanks for the reply's
We can just about anything as far as computers go, So no real need to get an IT guy, I have built our comps from new egg, I wanst sure what way is the best way to go for this situation and knew everybody here would be able to suggest the best route to take.
I do have an old dell desktop I can setup with a server os, If this is our best route
We dont need to be working on quick books at the same time
Both our comps are almost identical.
both-cooler master mid towers
both-asus p6t deluxe mobo's
both-Intel I7-920 cpu, hers is stock clock, mine is o'cd to 3.6 gig with aftermarket cooling ( Id do fps games at the end of the day, Stress Relief)
mine, evga gtx285 gpu, hers, asus top 4850 ati gpu
mine pcp&c Silencer 750 Quad Red 750W , hers, CORSAIR CMPSU-650TX 650W
both- WD black edition 500 gig hd
both-OCZ Platinum 6GB (3 x 2GB) DDR3 1600
thanks again
Ken
