It is currently Tue May 21, 2013 3:42 pm
 Post subject: replacing modem - do I need to reset router
PostPosted: Thu Aug 12, 2010 4:51 pm
As the title says, I am replacing my modem and am wondering if I will then need to reset the router.
 Post subject: Re: replacing modem - do I need to reset router
PostPosted: Thu Aug 12, 2010 5:37 pm
to accomplish what??
PostPosted: Fri Aug 13, 2010 3:04 am
Team Member Top 250
Team Member Top 250
If by reset you mean power off then back on, after the new modem is up, sure go for it.
PostPosted: Fri Aug 13, 2010 8:48 pm
Re-boot the router YES! reset no. The old modem has sent ip address info to the router so when you put in a new router it might pull a different ip address than the old one, therefore you need to reboot the router to get the new info.
PostPosted: Sat Aug 14, 2010 3:09 am
Thanks.
