It is currently Mon May 20, 2013 4:11 am
 Post subject: Does auto-update has anything to do with Networking?
PostPosted: Wed Jul 21, 2010 6:25 am
I am using XP home edition and my auto-updated never worked because I couldn't even select that option, does it have anything to do with networking? I have some of the things disabled like Marvel Yukon and 1394 Connction; and I have no idea what they are.
Any type of suggestions?
Thanks ahead.
PostPosted: Wed Jul 21, 2010 7:13 am
The only networking involved would be your connection to the internet. The only caveat is there may be a specific port that needs to be opened depending on the update mechanism.
The Marvell Yukon is a network card, but if you're using a different card, having this disabled is of no consequence. The 1394 Connection is a firewire connection.
What OS are you using what exactly occurs with the auto-update?
 Post subject: ...
PostPosted: Wed Jul 21, 2010 8:07 am
I was never able to enable the auto-update option (The Window XP OS autoupdate). I am just wondering why and when I bought the Laptop those network connections weren't there. they appeared after I installed Alcholo ??%.
OS? --> XP
PostPosted: Wed Jul 21, 2010 9:55 am
It's not dependent on whether a connection exists or not.
You probably want to post some specifrics as to what occurs with the auto update and what you've done up to now.
 Post subject: ack
PostPosted: Wed Jul 21, 2010 10:15 am
You got me there! I have no idea what I have done @_@ My knowledge is like a beginners (after, many many years of computer usage).
I think noone can help me, now. I can't even tell what's the problem.
