It is currently Wed May 22, 2013 7:42 pm
 Post subject: wrt54g and windows7
PostPosted: Wed Jul 14, 2010 7:36 pm
will i be able to use my current wirelessg router to conect my new build computer with a usb adaptor? i hate to move to wireless n as of now since i also connect my xbox360, printer and samsung netbook wirelessly through this router?
PostPosted: Wed Jul 14, 2010 9:10 pm
What does your set-up look like? You can connect all your devices though Wireless N or G. If you just use the WRT54g, all your devices will connect through G. The only reasons to move to N is for faster LAN or you are in a heavy G area among other things.
PostPosted: Wed Jul 14, 2010 10:40 pm
well i need to replace an adapter for the new computer i will build friday. just thought i read something about windows 7 and linksys not updating support for it.
PostPosted: Thu Jul 15, 2010 3:12 am
Team Member Top 250
Team Member Top 250
Just to make sure there is no confusion. If you have heavy G (or 802.11/802.11b which are 2.4Ghz) then you would need to use N in the 5Ghz range to get away from the interference. Otherwise you will see little to no improvement.
Windows 7 supports wireless adapters. I have seen problems with off the wall products, but that’s no real surprise. If you get a name brand you should be fine.
PostPosted: Thu Jul 15, 2010 3:30 am
thank you!
PostPosted: Thu Jul 15, 2010 2:06 pm
As long as you can get the drivers working for your usb adapter, then you should be fine.
