It is currently Thu Jun 20, 2013 3:27 am
 Post subject: Wifes Laptop is internet-slow when connected Wirelessly
PostPosted: Sun Jul 11, 2010 7:30 am
My wifes laptop is slow on the internet when its hooked up via wireless but when hooked up via ethernet its fine.
What could be the problem?
The router is a Dlink DIR-655
http://www.newegg.com/Product/Product.a ... pk=dir-655
PostPosted: Sun Jul 11, 2010 11:54 am
What are the wireless connection options available on the laptop's built-in wireless networking card? From reading the reviews on this particular router, it appears to drop wireless connections if you have the router set to use mixed mode with B/G/N (the default setting) if the laptop is using the wireless-G mode. That is the first thing I would check.
PostPosted: Sun Jul 11, 2010 2:16 pm
Team Member Top 250
Team Member Top 250
Could use a little more info, there are lots of reasons. Is the laptop near the router or on the other side of the house? What settings are the router set on? Can you see what the CRC errors are at? What security and encryption is in use? What channel is the access point on (or if it's on auto select)? What is the client laptop wireless card?
My guess with out really knowing this system is this: You are running a 2.4Ghz channel with 40Mhz wide channels. So turn that to 20Mhz and pick the cleanest channel (limiting them to channel 1, 6, or 11). From reading the specs about the router I don't see if it supports ccmp(aes), so if you have encryption turn on it will force the router to go to G speeds to support the older encryption methods (assuming you are not using wpa (or wpa2) with aes). Also remember data speeds and throughput are two different things. So if your data speed says 54 Mbps your throughput will hopefully be around 22Mbps (also remember that wired Ethernet is full duplex where wifi is half duplex). You may also have a source of interference causing problems or DRS (dynamic rate selection) is kicking your speeds down because of signal strength. But that's what I would look at first is the channel settings.
PostPosted: Sun Jul 11, 2010 5:09 pm
Its absolutely not signal strength as its a small house and it doesnt matter if were in the basement or right next to the wireless router.
The same thing happened when we were in the same room (the router and my wifes laptop) in the last house we lived in.
Heres a little more info, under wireless lan info. Not sure if this helps.
Wireless Radio : Enabled .
802.11 Mode : Mixed 802.11n, 802.11g and 802.11b .
Channel Width : 20MHz .
Channel : 6 .
WISH : Active
Wi-Fi Protected Setup : Enabled/Configured
Security is WPA/WPA2
Number Of Wireless Clients: 1
Mode 802.11n (2.4GHz)
Rate MBPS 26
Info from wifes laptop
wireless net card -Intel wifi wireless linkk 5100
Under channel it says 802.11 for band 2.1
Thats all the info I have for now, I hope that helps.
PostPosted: Sun Jul 11, 2010 7:32 pm
Million Club [PC]*
Million Club [PC]*
I'd suggest trying changing the wireless mode from its current settings (mixed B/G/N) to mixed G/N, if not G Only, and seeing how well it works then.
Simple, quick, and reversible if it doesn't help.
PostPosted: Sun Jul 11, 2010 8:56 pm
I am looking all over the router page and while I can find what my security is set to, I cannot find where to change the security to G only.
/edit After a whole lot more searching I was able to change it to G on the router.
Now is there something I need to change on the laptop to?
Because the wireless adapter has options also.
Let me know and thanks for the help.
PostPosted: Sun Jul 11, 2010 9:21 pm
Ok now Im really confused.
/edit Im starting a new post as I have another problem that is and isnt related.
PostPosted: Wed Jul 14, 2010 12:21 am
i think there has nothing to do with your router.
it's the wireless signal
i came across this phenomenon.
