It is currently Thu Mar 05, 2015 7:11 pm
 Post subject: wireless network problems
PostPosted: Thu Jan 27, 2005 9:30 pm
well i got an old laptop(pentium 1 100Mhz 40MB ram, 6GB HDD) from a friend on monday, and on wednesday i got a belkin wireless card for it. my mobo Asus A7N8X-E Deluxe, has built on wireless that can act as an access point. so i get the network setup, and it works great ecept for one problem. when i try to use the internet on my laptop after a few minutes i get disconnected from the internet, even though i still have full signal strength. the card in my laptop has the latest drivers, and is running windows 2000 pro, and my comp has the latest drivers. the only thing i can think of it, there is an option on my comps wireless software to enable Internet connection sharing, which i shouldn't need since my wireless card is bridged to my onboard NIC that is connected to my wired router
PostPosted: Fri Jan 28, 2005 1:59 am
team psycho or sumthin
could it be in the power settings on the laptop(OS or BIOS)?
BTW I have never used a laptop, so forgive me if I am talking out of my ass.
 Post subject: Re: wireless network problems
PostPosted: Fri Jan 28, 2005 5:57 am
doubt that's it...since your laptop CAN access the Internet via the workstation initially...then cuts out.
sounds like it could be a config problem...maybe on the worstation-side.?.?.? I had a similar problem that turned out to be the 'preamble' setting needing to be switched form 'long' to 'short' (or vice-a-versa can't remember).
PostPosted: Fri Jan 28, 2005 11:30 am
King of All Voodoo2 Cards
Check the power saving options on the laptop
PostPosted: Fri Jan 28, 2005 11:02 pm
i checked that,
and the preamble on both are set to auto
PostPosted: Mon Feb 07, 2005 4:47 pm
quick update, i switched which onboard NIC i was bridged to yesturday and i was able to stay connected for 34 minutes :) of course i can stay connected for 24/7 through VNC
