It is currently Mon Mar 30, 2015 7:21 pm
 Post subject: How to connect two computers in the same room?
PostPosted: Sun May 23, 2010 10:04 am
Yeah, I was wondering what's the best way to connect two computers in the same room. Internet doesn't count. I was more thinking about wireless LAN or maybe normal LAN. It's just that I don't know whether for two computers only, one needs a router of some kind?
PostPosted: Sun May 23, 2010 11:28 am
Monkey Fed [PC]
Monkey Fed [PC]
Do you already have a DSL/Cable modem? Do you have a router or a switch? Do you have provisions for ethernet, or will you have to go wireless? Need a little bit more information on what you already have installed before we can get you good answer.
PostPosted: Sun May 23, 2010 11:51 am
No.
No.
I think not.
My friend said that I should simply buy a wireless USB stick. Would it be possible to connect two computers just with two wireless USB sticks? So, without a wireless router or wireless switch? My friend and I want to play games on those computers. I hope the lag isn't too bad with it.
PostPosted: Sun May 23, 2010 12:43 pm
Monkey Fed [PC]
Monkey Fed [PC]
Wireless USB sticks would work, as would wireless PCI or PCI-E cards. You could also use a Crossover Ethernet cable if the PC's are close to each other. If the PC's are close, then the ethernet cable is your cheapest and fastest option by far. The wireless option is slower, more expensive, but it will work the best if the PC's are far apart.
PostPosted: Sun May 23, 2010 2:43 pm
Agreed.
A simple 5 port switch and a couple of ethernet cables would be significantly cheaper and the switch itself may come with short length of cat6 anyways.
Even something like this would work for just transferring files
http://www.google.com/products/catalog? ... DEQ8wIwAg#
PostPosted: Mon May 24, 2010 8:49 am
I think I will go for 2 Ethernet cables and one 5 port 10/100 switch. I'm afraid that wireless could be too slow. Thanks for help. :o
PostPosted: Fri May 28, 2010 6:31 am
If all you want to do is, connect two machines only. Get a cross over cable and plug it into each NIC port. Then enable file sharing and your done.
However, should you wish to setup an entire network with more than two machines? Get a switch, plug in straight through cables (a regular NIC cable) and then enable file sharing and your done.
If you do not want to have all the computers on at the same time and only have one. Setup a single computer and installed Server 2003 or 2008. Setup a basic Active Directory on a domain and implement a file server to store files. You then need to create a few user accounts and setup a group or two, etc... and your done.
PostPosted: Fri May 28, 2010 7:39 am
Hired Gun
Hired Gun
FYI modern Network Cards and Switches are auto-sensing so Crossover/Straight through cables are irrelevant in most cases. However having a crossover and several straight through's on hand is always a good idea just in case, since they are so cheap.
PostPosted: Sun Jun 06, 2010 4:47 am
The way I do it if I don't have a router and I don't use a crossover cable
All you need if just 1 ethercable
I use Dual Server which is a DNS and DHCP Server it is opensource
http://sourceforge.net/projects/dhcp-dns-server/
I set this up on one PC, then you can do what ever you want to do. If you need help with the config file you can PM me
If you wanted to do WiFi you would need to do a adhoc network.
PostPosted: Mon Jun 07, 2010 9:20 am
Malware specialist
Malware specialist
Flipper, bogara007, and everyone else stop it now. I have split out the arguing posts.
The original poster's question was answered and they have not provided any additional information as to whether going with a server is a viable option.
Anyone choosing to pursue an argument after this post will be saddled with a temp ban.
If you have any questions, feel free to send me a PM.
