It is currently Fri Feb 27, 2015 11:14 pm
 Post subject: Connection 1 - Network : Connection 2 - Internet, possible?
PostPosted: Wed May 12, 2010 6:23 am
Is there a way to specify which network connection an application uses?
Basically, want most of my stuff running off network connection 1 but this one app to run off network connection 2.
Is this possible and if so how?
Thanks!
PostPosted: Thu May 13, 2010 12:31 pm
Any ideas?
PostPosted: Thu May 13, 2010 1:33 pm
Not really feasable. If your MOBO has two LAN jacks and you have a router, you can use LAN #2 as a second connection, but you will have to disable LAN #1 for it to work which makes it a moot point. The only way would be to have two separate DSL/Cable lines.
PostPosted: Thu May 13, 2010 4:25 pm
Ya, I have ideas. But this is a "How do I do this?" question. This section is for folks with a flat tire in the middle of the Mojave. Try Networking Nook and playing with your router.
Very feasible. You're into instruction and not help though.
PostPosted: Thu May 13, 2010 7:34 pm
Million Club [PC]*
Million Club [PC]*
I'll agree with that.
Therefore, moving the thread to Network Nook. 8)
PostPosted: Fri May 14, 2010 4:32 am
Hired Gun
Hired Gun
If I have a flat tire in the middle of the Mojave can I get internet access?
PostPosted: Fri May 14, 2010 7:42 am
Sorry for posting in the wrong place.
So I either need to have connection 1 for my network and connection 2 for internet or more ideally connection 1 for everything else and connection 2 for a few applications.
Btw, I guess it might be important to note that connection 2 is iPhone tethered.
PostPosted: Fri May 14, 2010 12:18 pm
So what were your ideas.....? lol
PostPosted: Fri May 14, 2010 2:13 pm
Team Member Top 250
Team Member Top 250
Yes it can be done, but most companies don't allow it to happen. What OS do you have?
PostPosted: Fri May 14, 2010 2:58 pm
I suppose one could setup a proxy service on that machine and just tie that to use the 2nd NIC. A VM running a linux router (or the aforementioned proxy server) would work too.
This isn't exactly an easy thing to do and neither of which are exactly a light subject matter, but that should give you some ideas.
PostPosted: Fri May 14, 2010 6:24 pm
Take a look at FreeProxy. It can bind itself to a specific NIC. Then you just set up the one app to run through the proxy.
I remember pointing this app out to CrashTECH a while back for doing exactly this. Maybe he got it going.
PostPosted: Mon May 17, 2010 7:53 am
Windows XP Pro
Ok, will look at that application and info about setting up a proxy.
